Simple Ignition coil question
magialatina
I'm a newbie.
I just bought a set of ignition coil for my boat. The old ones didn't have the small spring inside the connector. This new ones all have them. My question is: How this little spring with a tail are installed? It could be to the cable side or to the spark plug side. I was looking at FAQ but nobody asked this stupid question.
bktheking
Re: Simple Ignition coil question
Spring with the tail- you are talking about the spark plug end. If you are replacing your wires, you pierce the through the center of the wire with the tail end do it goes through the wire core then slide the boot over the spring. I usually put some dielectric grease in the boot to aid the installation of the boot.
Joe Reeves
(Replacing Regular Spark Plug Wires)
(J. Reeves)
If you also need the spark plug boots and the spring terminals that connect to the spark plugs, purchase them from your local dealership (OMC Part #581027). This includes one boot and one spring connector. Price is about $3.25ea.
Purchase whatever amount of spark plug wire you need. Be sure to purchase the kind that has a steel twisted wire leading through the center of it....... not the carbon type plug wire that many automobiles now use.
Using your old plug wire, cut the new wire to a length about 3/4" to 1" longer. If you have no old plug wire, just make sure that the wire is longer than you'll need as you can trim the other end later.
The rubber boot, spark plug end.... With the wire cut to the length required, trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above. Holding the spring wire terminal, estimate where the prong should be inserted so that the spring will be flush against the exposed wire. Hold the spring terminal away from the wires end (sideways) and insert the prong into the insulation and into the center wire, then swing the spring terminal in front of the exposed wire portion (makes a tight fit for continuity purposes).
Spraying the inner portion of the boot where the wire will insert with a small amount of WD40 makes the installation of the wire a easy project. That's it.... you're done.
