Re: Single engine operation of dual engines
its an illusion... one engine is dragging the other one to similar rpm, even if the throttle is slightly more open on one than the other.
Very few twin outboard boats will plane with one engine. And, if you prop it to do so, then you will severely over-rev at wot with both running. hypothetical example: twin 200s run the correct wot rpm with 21p props, a single 200 would require something like a 13p to get the correct rpms on the same boat (and obviously be much much slower). and if you put 13p props on both engines you would have the same very slow top speed and the motors would probly barely be at half throttle to get wot rpms. hopefully that makes sense to you
you have to keep in mind that there is no transmission to take advantage of the power like a car has, its only one gear with one gear ratio. and, there is most definitely no connection between the two motors... even a 2013 four stroke outboard does not communicate with its buddy like you are thinking. your brothers old black maxes are very simple carbeurated motors, they will only spin what the prop lets them.
There are other advantages to twin engines besides getting back to port safely. If you use them properly, maneuverability around the dock is much improved (aka driving with the throttles, like larger vessels do). Also, twin outboards are often simply a necessity due to boat size.... what would you rather have, a 400hp single outboard?
another thing to think about, using only one engine while the other is fully trimmed out of the water places serious force on the steering tie bar (it binds up). I have personally seen them break from attempting this.
