Single lever control conversion?
bashr52
Is there any way I can convert my 1960 40hp Evinrude to a single lever control? It would make things so much easier.
Thanks
wilde1j
Re: Single lever control conversion?
If your existing two lever control isn't broken, I wouldn't bother. If you go ahead, you'll have to reuse your existing cable ends.
bashr52
Knob is busted off the gear selector, but other than that it works ok. I'd like to convert if possible. The cable ends are all still good on it. Is there a generic one available that will work with just switching to my ends?
wilde1j
I would try to find a knob. Try here:
Trixie?s Landing, Bayville, NJ 732-269-5838
American Outboard www.americanoutboard.com
http://www.piratemarinesalvage.com/
TD?s list:
Salvage yards.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
bashr52
I found a single lever control that will work! It's off a Johnson, but the cable ends are the same, and it even has the warm up lever which is nice, because mine doenst like low RPM to much unless its got some heat in it :D I'll post some pics once I get it and get it on.
