ski locker foam question?
ratking20
if i replace my deck and leave the ski locker out of the project. should i foam that compartment under the deck??
zopperman
Re: ski locker foam question?
Are you foaming everything else? I don't see why not.
ratking20
yes i am, just asking because the entire middle section is not foamed. what i mean is the bilge area, the gas tank compartment and the ski locker all dont have foam in them so is there a reason why the whole middle line is not foamed???
zopperman
A pic would help. The gas tank isn't foamed because it's aluminum and it needs to breathe or it will corrode. You can't foam the bilge because it needs to drain...
ratking20
i dont have any pics, but i think its pretty easy to understand what i mean without one, anyone else have any input on this?
zopperman
do you mean why the middle where all that stuff is isn't foamed by the factory?
ratking20
i understand why the factory didn't foam the bilge area, gas tank area, and ski locker leaving down the middle without foam. i just want to make sure there isnt a reason i should leave the ski locker area unfoamed even if i take it out of the restoration
chriscraft254
The ski locker area can be foamed in if it doesn't hurt drainage from the bow to the bilge. Foaming in your tank is also ok and add stability as long as you coat the tank with coal tar epoxy first.
zopperman
Yep. its now just any other big ol air pocket
rogergm62
hello.... Im planning to do the same in my bayliner..... foaming the ski locker.... I really don't like that hole!!!! and don have skies!!!! so I just was wondering if everything was ok... thanks....:confused:
