Skiing behind vintage StarCraft Jupiter
Hi all
Anyone pull a skier behind a vintage aluminum boat with an outboard? What tow setup do you use? I have a 1964 StarCraft Jupiter. I’d like to be able to pull the occasional tube/ski/wakeboard.
roscoe
doubt you'll get any wake for wakeboarding, unless the person weighs 450#.
Had a'66 Nassau that threw very little wake at all.
Skiing - a larger aggressive skier will likely pull the back of the boat around a little.
airshot
Depends how much hp you have, no reason it wont unless you have a really heavy person ! Back in 1964 I had a 14' mirro with an 18 hp evinrude and we skied behind that, getting up a little tricky but very doable. Also depends on the ski's, wider will be easier to get up on, skinnier will take more power.
jimmbo
Used to ski behind these, they could pull a skier in the high 20smirrocraft2a.jpg
