enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
I have narrowed my starting issue down to the Slave Solenoid from what I can tell based on the symptoms and my tests. If I jump the posts it starts every time, but if I use the key it starts sometimes, other times takes a few on/off/on motions to get it to go.
I thought it would be a super easy removal and install but after turning the 2 bolts I can now see that it is going to take a lot more disassembling to get it off. Can anyone out there share some tips? The Slave Solenoid is bolted to a plate next to the engine that also has a lot of other engine components on it. The 2 removal bolts just spin and I now realize there are 2 bolts that hold from behind and are inaccessible without removing that engine plate. I tried a few random ways but can't get the bolts to hold from the behind. Just to be clear, this is not the solenoid that is mounted to the starter, it is the one that sits higher up on the engine.
Can anyone share any tips on how to go about removing the Slave Solenoid and engine plate that also has the throttle control on it? I don't want to mess anything up while trying to remove the plate that holds all of these other engine elements. I also see that the metal fuel line is also held onto this plate but that may be able to be disconnected from the plate without removal from the carb.
I read around the forums and one guy said that he just bent the prongs that hold the slave solenoid in place, and put a new one in and bent the prongs back to hold it. That definitely sound super easy, but if I can completely remove and replace I'd rather go that route.
What could have been a few minute job is not any more. All help appreciated!
