Jerome Lowery
Thread starter- Joined
- Jun 21, 2016
- 14
My grandson has a 1972 19' Slickcraft boat with a 188 hp 302 Ford engine. Had it on the lake running smooth then it just quit. The engine runs fine but the prop quit turning. Now out of the water, checking finds starting the engine and moving shift/throttle fwd engine revs but no shaft turning. Shift to neutral, engine stalls every time. On the transom inside, there is some type of looks like a hydraulic tank with solenoid and wiring (marked use engine oil). No idea what it's for. I would really like info on this problems, especially the one on the sterndrive not engaging at all. The prop just spins freely. I really don't think there is mechanical problems with the sterndrive. THANK YOU. Jerome....
