Slightly bent skeg
airdvr1227
Just noticed it this morning. Ok to bend it back? It's not layed over...just a slight bend...to port :D
WAVENBYE2
Re: Slightly bent skeg
Ya my new/used one is slightly bent to, I haven't noticed any performence problems though, I am afraid that if I try hitting it too hard that I will crack it, I think its aluminum alloy.
5150abf
If it doesn't affect perfomance I would leave it alone, if you snap it now you have a real problem.
If you absolutely must straighten it use 2 hammers and TAP(tap: to hit slightly harder than you would your own finger) it back into place using the heavier hammer as a backer, you don't want to just hit it as it will bend somewhere else.
marine4003
Noyhing wrong with slightly bent..hey, just look at me...
Bart Sr.
This is probably your safest DIY method BUT--Use rubber hammers.
IMO
