Slipping at higher RPM ?
jaybird56
I have a 15hp evinrude on a 14 ft alumcraft flat bottomi think it is late 90s engine model number looks like a E15ROOS. I was on kind of ruff water and had been about half wo and speed up to about 3/4 wo and couple minutes later it kind of reved up and speed fell off i quickly backed off gas then turned it back up a little and it picked up speed again. I went on to dock with no other problems. What might be the cause of this ? Thank you for infomation
Daviet
Re: Slipping at higher RPM ?
Cavation because of rough water, slipping prop hub?
jaybird56
Thanks Daviet i will pull prop and look at it not sure what to look for
Vic.S
I don't think model number is correct ...OO for the year code does not make sense.
Test for spun prop my marking the prop and the shaft. Go for a run until it "slips", then check the marks . If they do not line up its a spun prop hub!
phillnjack2
Ensign
is the engine up a bit too high ?
is it shortshaft engine on longshaft transom ?
phill
jaybird56
model number might be CC for year code i cant find out what year engine is for sure
boobie
Scribe a mark on the prop shaft and the prop. Take it out and run it and if it slips again, check the marks. If they're out of alignment you have a slipping prop hub.
Vic.S
The year code letters are the word INTRODUCES, I=1, N=2 etc up to E=9 and S=0
So CC would be 1988
it looks ok to me a couple inches below bottom of boat?
Thats the AV plate a couple of inches below the bottom of the boat ??
Thats OK, if anything a couple of inches lower than necessary
jaybird56
88 is what i came up with too but i thought 88 and 89 didnt use butterfly type choke which it has and there is a small sticker by the fuel hookup that says to run 100/1 fuel ratio, and it has the slots to put a water hose and huff on it, i have a 89 model 8hp that dont have water hookup
jaybird56
AV plate? bottom of boat is a little above prop
Vic.S
Antiventilation plate. The plate above the prop. Its purpose is to stop air being drawn down into the prop.
(Sometimes incorrectly called an anticavitation plate.)
The AV plate should be a level with the bottom of the transom. Up to perhaps a couple of inches lower will be OK but the lower you mount the engine the greater will be the drag. Much higher and you run the risk of air being dawn into the prop.
The 100:1 sticker makes it 1985, 86 , 87 or 88. I think by 1989 they had given up on 100:1 but not exactly sure what year they did that.
( not running yours on 100:1 I hope)
All those years ITYWF had butterfly chokes. In fact later ones too except where electric primer pumps were fitted ( to electric start models I guess)
They all also had water intakes that muffs could be fitted too.
You cannot, except for the fuel mixture issue, compare them with the 8HP models IIRC manual primer pumps were fitted to some 8hp models ( 86 to 89 ??) but I don't think muffs could be fitted to any.
jaybird56
Thanks VIC for information i am kind of new to boats, use to to have a 24 ft smokecraft always sent it to shop to repair i didnt have time but had money now more time then money so now i do it myself
