boaterntexas
- Joined
- Feb 4, 2003
- 254
My 1976 115 hp merc has been having so drive problems. We ran aground and ran the motor through some really thick mud, the motor seemed to of slipped a couple of time but nothing serious, since then I have changed out the impeller. the first trip in the water with after the runaground/impeller change, the motor started bogging down, which then turned into slipping, no force on the prop at all, it appreas to be turn some, but not enuff to move the boat, the motor sound like it is reved up all the way. Any Ideas on what the problem could be, diagnostics, and estimates of cost to fix the problem. Oh yeah, the after the impeller change the motor ran fine out of water. also when I changed the impeller it was really ill fitting when I was putting the housing back on. there is alot of water comming out of the top two "exhuast" slots. I had lots of trouble getting the L/U back on and the shaft lined up properly, could there be a bad connection there. also the copper pipe that was there, could it be not connected to somethign up top that it is suppose to be connect to. ONe more thing, there was a screw that went through the impeller housing that seemed to never get tight, it was the one closes to the prop, the one that was not a bolt it went directly into the Gearcase, is this normall<br /><br /> so this post is so long winded and rudundent form other post, but I just want to provide as much info as possible. <br /> thanks alot guys.. <br /><br /> Thomas
