spacerust
Thread starter- Joined
- Feb 18, 2008
- 190
I just bought a new prop a little over a month ago. I have a Nissan 90HP and put a 13 pitch prop to get my WOT at 5300 with a full load (3 people, 15 foot shallow sport, and gear, 3/4 tank of gas). I did this so when I have less load I would be close to 5500rpms max. Well the last few trips coming in I've noticed that rpms would spike a bit close to 6000 rpms and I would lose speed. I though maybe I needed to redistribute weight and getting air underneath the prop and went out the following week and had more weight in back. It did the same thing. I fish in real shallow water, sometimes as shallow as about a foot. At first I didn't know how to get a good holeshot, but figured out that if i have my passenger(s) lean right on the boat (tunnel hull) that I was able to get out circling pretty quick. But the first few weeks I just tried to drive straight out. This past weekend when I got to about 5200-5300 rpms i would kind of feel like it was slipping. When I'm just at half throttle or less, everything is ok. It is when I try to go full throttle i spike and lose speed. Now...
I live pretty far from water so I read that if you put the boat in gear and try turning the prop if it turns you may have some slippage. I put it in gear, grabbed the prop and tried turning it. Is the prop suppose to turn at all? I am able to turn the prop but it feels like I'm turning a gear and I hear like a whoosh, like when you are turning a cylinder and hear the compression. Is this normal or do I have something other than hub slippage?
