Thomas1981
Thread starter- Joined
- May 26, 2013
- 19
Hello,
I'm new on this forum and I really need your knowledge. I have a Bayliner 2655 from 1997 with a Mercruiser 350 MAG and Alpha One Drive.
The boat was the whole winter in the harbour (in the water).
After testing for the first time this summer the propeller started slipping around 2500 RPM. Boats slows down and RPM goes slowly up.
I replaced the propeller(+ hub en washer, org merc. same diameter and pitch) because this had to be done anyway but the slipping is still the same.
Before testing for the first time this year I changed the oil+filters and placed the thermostat. (The previous owner took it out and the engine was always running on 140F).
My questions are:
Are there components in the drive that can slip, except hub? Is there a hydraulic clutch in the system?
There are algies on the bottom of the boat. Of course this slows down the boat, but can it also cause the slipping of the prop?
In which situation can the exhaust gas causes cavitation?
I hope you can help with this problem.
Bye Thomas
My questions are:
Bye Thomas
