Slow plane at high altitude 5.0L MPI, please help
Scott06
I'm not sure what RPMs I'm at, the tach while I'm on water never says anything above 3000, but my ear tells me it's probably higher than that, though I could be wrong.
I purchased the RPM laser tool, I'll try to get an accurate reading to see how far off the tach is if any. I can't imagine this boat doing 45mph at 6300ft elevation and only being at 2800rpm (with the 4 blade 18p), but I suppose anything is possible? I doubt it though.....
No not that speed at 2800 rpm I think you just want to know the prop is such that you can get to the upper end of the wot rpm range for both of your altitude situations likely u will need different props for different situations
F lmk
QBhoy
Get a VesselView mobile. Best thing you’ll ever buy for your mpi or any other modern merc engine
