SLOW sensor on 60 hp
DHPMARINE
Self diagnosis is great ! But if you need answers beyond that ,post more info.
DHP
buzzman 9403
overheat sensor comes on replaced lots, to check alarm sensor i will unhook,if the engine overheats will the SLOW sensor still kick in
Silvertip
Re: SLOW sensor on 60 hp
Rather tough question to follow. Here's my take. You don't have a SLOW sensor. You only have a TEMP sensor. Overheat conditions are detected by the TEMP sensor which turns on the SLOW mode circuit built into the power pack. Call me curious, but wouldn't you want to know if your engine overheated? With the temp sensor connected and operating, if your engine overheats two things happen: 1) alarm sounds and 2) SLOW engages which limits engine to 2500 RPM. With the temp sensor disconnected you get neither of the two warnings. Oh yes -- you get one more warning -- the screech of a siezing motor. If the sensor is bad, replace it. They are hundreds of times cheaper than an engine.
