1983 75HP Evinrude. I had a problem with losing spark on #1 Cylinder. Mechannic replaced timer base wiring (burnt wire) and it ran great with just me onboard. The other day I had three people in the boat and it would bog at take off if both guest sat on the bench by the transom, it would be stuck at about 8 knots. If one of the guests would move forward, either next to or forward of the center console, the motor would catch up and run great, 30 knots. They could then move back to the bench and no problem. At idle it is firing on all cylinders. No rpm gauge. Any ideas? Compression good at 125psi on all 3.
