Slower speed and less rpms. Timing?
adamfsunrunner
I have a sunrunner 22foot boat with a merc 5.7litre V8. 260hp. I have lost about 500 rpm and about 8 or 9 mph on gps. I'm wondering if it could be the result of timing being off. I had a manifold and riser put in last season and the boat slowed down after that. Fuel has been checked..carb is good...prop is good. Is it time to put a timing light on the engine??
Thanks.
Don S
Re: Slower speed and less rpms. Timing?
You don't just replace one side when doing manifolds and risers, you do both.
You need to do a compression test and see if the engine has any problems before you do anything else.
Then some info as to what year and model engine and drive you have would be very helpful.
freddyray21
if you had the manifolds and riser both changed and it dropped rpm's after that then look to the manifolds and the riser. Possibly smaller ports on the new manifold?
newport dave
It's possible they did not install one of the exhaust shutters correctly and it is not able to open fully or fell down in the Y pipe. No easy way to check for this, you would have to pull the risers and do a visual inspection.
Dave
adamf24601
well...from what I'm reading no one seems to think this is a timing issue?
Don S
You've never mentioned what year it is either.
freddyray21
first rule of thumb if you do something to your boat and it runs worse after you did it look to what you just did.
freddyray21
one way to tell stick a timing light on it and check it
