slpit tilt/trim cylinder
stubblejumper
I went out to trim up my 75hp Mercury 4 stroke engine after installing the batteries,and the engine only lifted a short ways before stopping.Hydraulic oil was pouring onto the ground,and I noticed a long split in the tilt cylinder.The boat has not been used since last fall and it worked fine then.The trim worked after the last use.Any ideas as to the cause?
stubblejumper
Re: slpit tilt/trim cylinder
I spoke with my dealer this morning,and apparently this is not all that uncommon.He suspects a defect with the cylinder casting,and he assures me that it is covered by warranty.
