Sludge in the bilge area, best way to soak up?
superharmonix
I have a small pool of cludge, looks like oil and gas in the bilge area of my 1978 Chrysler Bass Runner. (outboard of course)
The previous owner had removed an under the deck gas tank and I believe it may have been leaking and that's where the sludge came from.
My question is, what should I use to soak it up and get it out of there?
not enuf toys
Re: Sludge in the bilge area, best way to soak up?
why not dissolve it with a degreaser or kerosene? let it soak for a little bit and drain it out the plug into a bucket? you could then take the mixture to a recycle place (auto store).
superharmonix
My drain is slightly off to the port side, and the pool up of sludge is in between stringers on the starboard side, so there's no way to fully drain that side. It's not up to the bilge pump. If it were merely water, I would suck it out with a wet vac.
Herein lies my quandry.
FlyinGuy1017
Soak up any standing stuff with shop towels (like the disposable blue ones). To clean, use Oil Eaters (avail at autozone). That stuff is non-toxic, non-caustic, won't dull any paint or finishes (doesn't even burn if you get overspray in your eyes), and breaks up petroleum based products well. Liquid dishsoap will work, but takes a bit more scurbbing/rinsing especially if using cold water.
Good luck!!
'78 Crusader
Good luck!!
I've used Dawn dish soap before and it worked surprisingly well.
Knot Waiting
X2 409 or Purple Power works well for removing the final film
I second the Purple Power as a good degreaser. Works great in both marine and automotive applications.
Fireman431
Any of the cleaners mentioned work very well, including tide detergent. However, you are going to have to get the majority of it up first with paper towles or rags and then just clean up remaining residue.
superharmonix
I saw these things somewhere shaped almost like a boat bumper, and were covered in a type of netting to be used to soak up oil and gasoline. I can't remember where I saw them, or what they were called. Have any of you seen anything like this??
I may end up soaking up with towels and bagging them up, but if I do, where can I dispose safely?
By the way, thanks for all the tips so far!!! Much appreciated!
partskenn
Simple Green also works well, biodegradable too. Around here we would buy those absorbent pads, mats etc. at a place called Safety First. They sell fire extinguishers, safety clothing, construction safety equipment etc.
RZR2007
Pig mat will work very well for soaking up the oil and gas....
superharmonix
thanks for all the tips!
I am going to soak up the sludge with shop towels.
then, I am going to wash it out with Simple Green or Purple Power.
