brokeboater
Thread starter- Joined
- Sep 17, 2002
- 103
i have a 99 200 Johnson i can not figure out a problem with. i have checked compression. 95+- on all cyl. checked fire on all wires with timing light while running on hose and all are firing. it seems to run pretty good in the yard on hose and will readily rev up. i can take down to the local ramp, back it in and start it up but when i give the gas it all but dies. carbs have been removed and cleaned, plugs replaced, anti siphon valve removed for test and fuel line replaced from separator to engine all to no avail. last time i was out it did this for first ten minutes or so. i figured i was going to have to put back on trailer but after babying a bit it went ahead and run good rest of day. now its back to same issue. it doesn't seem like fuel issue but i can't be sure. it prob should be noted this engine is used only every few months and what ever happened did so between trips. any ideas what to check next? Thanks in advance
