Sluggish sport jet 90
k_hicks
I have a 1994 Donzi with a Mercury Sport Jet 90, Force engine I am told, which cranks and idles good, just sluggish to plane out and not as much speed as it use to have. Would run 40 mph tow years ago now only about 30 mph. Change stator two years ago, changed switch box last year. Clearance on wear ring is .008 which I believe is good. I was told that the stator has a low side and a high side in it, is this correct. Just cleaned all carbs, good fuel supply, new plugs, all firing at low rpm, what about timing and how do I check it. Also would like to install a tach but dont know where to connect to. I would certainly would appreciate any help.
Ken
maxum247
Re: Sluggish sport jet 90
Look for air leaks in the fuel line or fuel pump, restricted fuel filter.
Check for a choke or throttle valve that operates improperly.
Check ignition timing adjustment.
Do a compression test on engine, see what the numbers are.
Look for loose bolts, defective gaskets or leaking mating surfaces on the cylinder head.
k_hicks
120 to 130 psi on all three, new fuel lines, tank vent not clog, dont know how to check timing
maxum247
If you don't have a manual , pick one up it's been well worth the $35 I paid for mine!
You can search here on the forum for topics on (engine timing.) Use the search button at the top of the page.
From what I know of compression numbers yours sound to be ok!
The main thing is for them to be within 10 -15# of each other and preferably over a 100# on each cylinder.
k_hicks
Timing was way off, better pick up now, narrowed the skip down to no. 1 cylinder, good spark, runs good for a few min. then starts skipping, can hold my hand over carb intake when skipping and no change, believe i have a fuel shortage, guess i will clean that one again. Any tips anyone, thanks for the timing tip.
Ken
maxum247
Ken
Sounds like the coil on the number one cylinder may be getting hot and braking down once the engine warms up.
k_hicks
swapped no. 1 and no. 2 coil and plug wire, still in no. 1
maxum247
Have you tried a different sparkplug on that cylinder, switch with another plug from a firing cylinder and see if the miss moves with the plug just for kicks, I know you said it fires at idle, but who knows.
k_hicks
new plugs and have swapped them, going to take the carb now and clean it again. Let you know around lunch.
This thing is driving me crazy
k_hicks
I give up, it going to the shop, then it will get a big FOR SALE sign.
k_hicks
sure, ill try anything at this point, and i appreciate all the help
maxum247
In the begining you said it was sluggish to plane and doesn't develope full speed.
Are the throttle valves in the carburetors in sync with each other and opening fully (Horizontal), anything less or more will cause the engine to either not reach full power, or bog.
When was the last time the fuel pump was rebuilt or was it?
Check the fuel system for air leaks again.
Check the idle adjustments on each carb and make sure there in sync with each other.
May be time to decarb the engine, get rid of the carbon deposits on the pistons.
k_hicks
have narrowed it down to no. 1 piston, and it is intermittent, when it does skip i can choke out no 1 with my hand and nothing happens, choke no 2 or no3 and the engine dies.
maxum247
Carb may be out of adjustment, not sure.
Half of the CD module for that cylinder may be giving out.
I've heard that the metal connector in the rubber boot that plugs on to the sparkplug end can loose contact with the sparkplug causing the engine to miss on a cylinder.
Some people replace the sparkplug boots with screw on boots for motorcycles, instead of useing the type that came on the engine originally that peirce the wire end.
k_hicks
is the cd and swithbox the same, im thinking that could be the problem, carbs all adjusted, and in sync, 5 psi on fuel pump, is that enough
maxum247
Sounds ok on the fuel pump, usually somewhere between 4 and 6 psi I beleive.
If it doesn't have two blue or black CD modules it would be a (switchbox).
Sounds like (Thunderbolt Ignition). I'm not that familiar with that setup but the principal will be the same.
k_hicks
Problem solved, bad trigger, back up to 40 mph and quick out of the gate, thanks guys
maxum247
I'm glad to hear that it is running well again!
Thanks for letting us know how things turned out!
k_hicks
You are welcome, great site, lots of free information
