Small crack in hull
bsh21wash
I have a small crack in my hull, dont know if it goes all the way through or not but would like to take care of it before it gets worse. What would you guys recommend to repair this? Filler? Resin? thanks -Brian
michael-lagrange
Re: Small crack in hull
Find out how deep it is, then you will know, is it a paint repair or deeper, if deeper i would bump a grinder on it to rough it up and do a fiber resin repair.
andy6374
Does the crack leak? Is it just cosmetic?<br /><br />Some pics would help.
epresutti
bsh21wash,<br /><br />Like Andy said, you need to find out if it is structural. A picture would be nice. If it is along a chine you need to take a hard close look at it. If it is just a spider crack (radiates from a center point) you are probably OK.<br /><br />Let us know.<br /><br />Peace.<br /><br />Ed.
bsh21wash
I dont know how to post pics on here, but the crack is on hull where it kinda steps up, kinda like a ladder. Cant really tell if its major or not.
lingcod
bsh21wash, where in kent are you located. I am on the east hill just off of kent kangley road. I would be happy to come over and take a look at it if you want.
epresutti
bsh21wash,<br /><br />This is a picture of a fracture that was in my hull, I ground it out so you only see V that was left and I repaired it from the inside first. It is right on the chine, a very bad place for a stress crack since in my boat the stringer runs along the chine.<br /><br />
<br /><br />This is my Whole Project. <br /><br />In order to post pictures here you must provide a link to the picture. So upload the picture to your own site (or a public place) and then use the full reply form and click the image button. Type the URL of the path to the picture and it will appear in your text.<br /><br />Hope this helps.<br /><br />Peace.<br /><br />Ed.
bsh21wash
Hey well i threw some marinetex on it and gonna call it good for the weekend. Ill take further action on it later. Thanks - Brian
jbezanson
If it is on the part where it "steps up like a ladder" that sounds like the chine, if it is through the glass, you will want to make the repair from the inside as well as out, otherwise it will most likely reopen. Keep an eye on it with the MarineTex.
andy6374
Originally posted by bsh21wash:<br /> Hey well i threw some marinetex on it and gonna call it good for the weekend. Ill take further action on it later. Thanks - Brian
This is fine as long as you know that this is temporary fix, should get through the season though (unless you hit something).
