Small crack in lower unit near prop, how big of a problem is it?
Drcoffee
the wife and I took out the boat for the last time this season and had a great day out. While putting the boat away I thought I saw some paint peeling, but no, its a crack about 1.5” long at the top of the prop on the the lower unit. Is the unit toast, can it be welded?
boat is a 1995 Rinker 212, w/ Mercruiser 5.7 carb, Alpha one outdrive. Heres a couple of pictures.
achris
More fish than mountain goat
That crack is caused by corrosion building up under the cover nut. You need to remove the nut, pull the bearing carrier and take the housing to a welder...
If you leave it, it will just get worse.
Chris...
