Re: Small current "back" into my charger - unplugged
OK, here's my update (still having issues). Maybe someone has something I haven't tried. I finally got tired of taking my battery back (it tested fine 3 times) and got a new one. Same problem. Runs like crazy some of the time. Won't hardly crank the engine others. I can take it right off the charger and get the same intermittent behavior. I've removed the power cables from the battery and cleaned (again!). I use carbon conductive grease on all my connections (
http://www.mgchemicals.com/products/846.html). I worked with a guy who built ocean sensor moorings and he swore by this stuff for making good, corrosion-resistant connections. I can say over the years, I have never had an electrical failure where I used this grease.... SO, I think my connections are all good. I'm getting a solid 12V at the solenoid (greased), When I manually "short" the solenoid, I get the same issue (sometimes cranks like a champ, other times, slow and sickly). The cable to the solenoid seems serviceable and I've cleaned and greased the connections. From experiences with trailer lights, I've always found intermittent problems the result of faulty grounding. I removed, cleaned and greased all my grounding points (including the starter mount). So now, I'm really starting to get flumuxed!
Here's one anomaly. Twice, I had the battery indicating full charge (and the charger still on). I went to crank the engine, and it was completely dead - I couldn't even get the choke to engage. After unplugging from the charger, the choke functioned and it was able to crank (slowly this time).
I don't know how I can check the resistance of the master cable (service from cranking battery to engine). I put on a multimeter and got 0 ohms, but if there's some "internal" corrosion (which I tried to look for), I can't really tell. I can't find a replacement cable part (maybe you just have to make them?) for my model ('83 Johnson 60HP). A colleague suggested maybe the rectifier was faulty (he had issues with charging and would have trouble starting after running for a while). I'm guessing this isn't the problem - 'cause I put mine on the charger while it's in the garage. I was thinking perhaps my solenoid might have some corrosion on the contacts? I don't know if the solenoid(s) in my vintage engine are solid state or mechanical, but I figured I could use a spare (for $30).
My next thought is to take my battery out, and hook it up directly to the solenoid using jumper cables. Anyone agree with this test? This would let me know if my main service cables have too much resistance (perhaps). What's killing me is that the problem is so intermittent. It'll crank like gang-busters one try, then the next, just chug and labor (too slow to start).
Anyone have any other ideas???? Thanks!
Tom
