Small water leak volvo penta 5.0gl
dmiles3566
I have a small water leak behind the water pump housing where the water pump bolts to. Is that serviceable and will it harm the engine if I use the boat normally?
BRICH1260
Your pump bearing seal has crashed. Just replaced mine. I would attack it soon as the bearing will be rusted and water will be thrown all over your engine compartment. You can rebuild the existing one or buy a whole new unit for a couple hundred bucks on Amazon and replace it quickly.
Ayuh,..... Welcome Aboard,..... What motor,..?? What vintage,..??
