Boat and motor in sig. <br />Sorry for long detailed post.<br /><br />Original prop numbers were not readable.<br />Measured and it was 13" diameter.<br />Specs in OEM manual suggested standard equipped prop was 13x19.<br />Prop is not stainless steel or aluminum, as a magnet easily sticks to prop.<br /><br />Test with original prop had two of us, plus 35 gallons fuel, at max WOT of 4800RPM (new Teleflex) and a max speed of 38MPH GPS. Fuel was old and treated, so original test was really just to use up all the old gas, and how the boat/motor were after being stored for 15 years. (carbs and maintenance was done prior to test).<br /><br />Based on what I read here, we need to get RPM's up near 5800. After testing, noticed some good size stress cracks on prop. Replaced with Michigan 13 1/4 x 17 aluminum (11003), to help bring RPM's up. Guessed that new gas, new prop, plus doing a link and sync would get us to our target RPM's.<br /><br />Now with new prop, 3 people and 40 gallons new gas, but link and sync not yet performed, best we could get was 4400 RPM and 31 MPH. Also with new prop, sometimes if I wasn't carefully accelerating, prop would blow out or wash out or cavitation (or what ever the term is when RPM's suddenly rise, yet boat slows when powering). It was like motor was now to high on transom (fully trimed down)?. Looking at motor, and it was about 3/4" above top of transom, so thought we could lower it down. Another possibility of cause was new transducer that we also mounted about 12" starboard of center line. On return trip we raised transducer, and the cavitation appeared to be gone.<br /><br />We also changed Power pack right before test, so if the new PP4 (yet looked like someone else had opened and possibly installed it) was defective, it may have caused lower RPM's? We plan on putting old prop on for one more test, just to confirm PP4 is good, and see how it works with transducer. Transducer needs moved anyway, as it fails about 10MPH. <br /><br />Of course we know link and sync will need to be done.<br />But, that would not have caused the issues.<br />Lower RPM, speed and cavitation.<br />Could transducer be whole cavitation problem?<br />Is motor too high? Should we lower it? Old prop never cavitated<br />Is old steel(?) prop worth fixing, or obsolete, plus too large (or small)?<br /><br />Thanks in advance,<br />Rob
