Smart Tabs Install. Question
Holycow
Howdy Folks,
I have been digging thru the archives of the boards to see if my situation has been addressed for someone else, but evidently not.
I have an 18' 1958 Lonestar El Dorado with a 1986 Evinrude 60Hp (w/ carbs from a 70) on it and recently ordered myself some Smart Tabs.
The hull itself is a V shape in the front and then transitions to almost.. but not quite flat by the time to get to the stern. At WOT GPS tells me top speed of 32 mph. The hull is stable in the water, but does take a LONG time to plane off, plus the prop grabs air and comes off a plane if you try to manuver too much while moving along.
The engine is mounted on a bracket about 2 feet behind the transom. There is space either on this bracket for the tabs, or on the transom.
SO.. which is better, having the tabs as far apart as possible (for roll stability) or having them as far back on the boat as possible for max lift?
Any words of Wisdom?
Thanks.
--Jeff
RickyHenry
Re: Smart Tabs Install. Question
Howdy Folks,
Thanks.
--Jeff
Go transom mounted.
nlain
Mount on the transom as far outboard as possible.
tashasdaddy
agree. and your motor may need to be lowered an inch to increase bite, lessen ventilation. what are your wot rpms, may need to reprop.
Ayuh,....
The Tabs go on the Hull,.... Not the motor bracket......
Jdeagro
iboats.com Partner
Trim tabs should be an extention of the hull.
Holycow
Right on!
Thanks everyone for the help.
My boat is fully functional, but pretty rough right now, the plan is to get her in top notch shape for a few overnights in the Keys.
My wife and I went to Islamorada (in the FL Keys) last summer and she did not have a good time on the water. When she started referring to the Lonestar as "Hate Boat" I figured I'd better get going on making it more comfortable. I will post pics of the boat and my progress for anyone who might have similar plans. The smart tabs will go on in the next 2 days. Then it's out for a test run.
Hizzah!
--Jeff
tashasdaddy
man i would love to have that boat. i had a little 14 ft lonestar, super boats.
