GreggBrightwell
- Joined
- Apr 1, 2016
- 11
So I bought a 1986 Stratos, with an Evinrude xp150, a few months ago. I bought it for a song, knowing the motor wasn't right. I've replaced lots of parts- thermostats, rebuilt fuel pump side of VRO, six new check valves for the manifold, one new power pack, set timing via Reeves, new plugs and wires, rebuilt all three carbs. After several iterations of taking it to the lake, and not being able to get it over 1800 rpm in gear, I found I was losing spark on a cylinder. Replaced that side power pack, and finally got it going great yesterday. Water pressure seemed real good at idle, and at power. I took off down the water, making big circles near the ramp just in case. This boat flies! I saw 55+ on the gps, and wasn't even WOT. I was trying to ease into WOT, and find the sweet spot on the trim, when it started cutting back on the rpm a bit. I looked back, and something sounded wrong so I pulled it back to idle, and shut it down. Noticed some smoke coming from under cowling, so i took the top off. Definitely smelled electrical, and was smoking pretty good. Would not restart. (would barely turn over, actually) I have a rocket of a trolling motor, so that got me back to the trailer. After a little while, the engine cranked fine/normal but wouldn't fire a lick. It seems to me, that I might have cooked my stator. I don't think I overheated the motor itself, as I am pretty well certain that the water circ was still good at speed, ( it was hard to hang on with the rough water) I have new thermostats in it, and i do have the SLOW feature. The lower unit seems fine, good rotation, good shifting, properly serviced, etc. I'm still right side up enough on this boat to buy a stator if I have to, but I don't want to spend a fortune on a 30 year old motor. What do you guys think? Sorry for the long post, but wanted to give all the details I could to help with the troubleshooting.
