Imjus4u2nv
- Joined
- Jun 10, 2013
- 57
Hi all,
I want to thank you in advance for reading this- this is a great community.
I have a 1986, MERCURY - ( 90 H.P. (1986 )) Serial No: 0A968445 Model No: 1090726
I was driving home the other day when the engine made started smoking so I cut the engine right away. Even after being turned off she still smoked for another minute or so. I opened up the enngine cover and all the wiring was very hot. I had a problem in the past with one my stator wires, and i am uncertain if this is related but the other stator wire (I replaced one) had no insulation on it and was apparently touching the engine case (grounding).
Got towed in, was able to restart but shut down while i pulled anchor and was gonna limp in but then couldn't ztart back up (I have been having sporadic issues with thh starter and I am still troubleshooting but will save that for another time).
I get back to the dock, solder a new stator wire extension on (two new wires now so thats done), check all the plugs and find one very badly fouled spark plug, but all the other plugs look fine. (see picture)- very hard gray deposits, plugs are almost brand new (installed a month or so ago). I swap out hte plug and get the boat running, let her idle at low rpms for about half hour with no overheating or smoke, no fouling on spark new plug, but have/will not take it out for a full test run until i know more (to avoid additional damage). It may smoke/foul plug when I drive it at higher rpms.
Now the engine is leaking water around all (at least 5 of the 6) spark plugs, which from this site I know is the gasket for the water jacket cover.
I was hoping someone could guide me through the install for the water jacket cover, mainly finding the right gasket. I believe i need part #22 here- http://www.crowleymarine.com/mercury-outboard/parts/278_15.cfm Also any main tips (besides don't break the bolts)- is this an easy fix, will i see the bolts i need to remove?
Also does anyone know why all the spark plugs would be leaking (they were not leaking prior to this (or at least a week ago). I am assuming the engine overheated and blew the entire gasket?
Is it possible the shorting wire somehow messed with the ignition in that cylinder (the wire to the 3rd cylinder looks like it got the hottest and I will replace) and that is what fouled the spark plug. IN other words if I fix the gasket do you think i am good to go?
