Smoke from engine, one badly fouled spark plug, and water leaking from all all plugs
snowbrd84
Re: Smoke from engine, one badly fouled spark plug, and water leaking from all all pl
I had a spark plug look like that after my lower main crankshaft bearing went, a ball bearing made its way into cylinder 6 and destroyed the piston and the head surface, aluminum shavings then coated the spark plug just like yours looks. Funny thing is, after all the debri settled in the back of the motor, the engine "ran" perfectly on five cylinders. The problem is, if you have debri in the motor, which it looks like you do from that plug, running it is going to result in completely ruining your motor eventually..
