So I rebuilt this motor over winter. Rebuilt carbs also. Set base ignition timing. Set high speed timing. Was out on river running it. Prob got 10 hrs on rebuild running 25/1 mix fuel. Got into it about 3/4 throttle for about 2 minutes. Motor rattle some and stalled. Wouldn't crank. After sitting for bit, started. Ran decent. Got home and pulled side transfer plates off. Found all piston perfect but number 5 (bottom right) scored bad. When rebuilt carbs, removed welch plugs to make sure clean and installed new ones. Jets are .002 over stock for the .040 overbore. When took carb apart last night, was careful so could inspect for plugged jets. Found none. Did notice when dumped bowl on metal top bench, had about 4 dime size water spots floating. (Was raining bad earlier that day). Possible that little bit of water kept my fuel/oil away on just the one cylinder and not the other that shares carb. Anything else I can check to prevent this again?! Thanks.
