ziggy
- Joined
- Jun 30, 2004
- 7,473
i got this....
a smokey bathtub ring around my boat. i wash it off. take it out once and get it again....
my plugs also show signs of cold fouling. , dry, black deposits, sooty. i'm using ngk br6fs plugs which i believe is the sub for ac mr43-t.
i also do a lot of slow cruising. 900-1500 rpm....
for cold fouled plugs, possible problems are. that i'm aware of...
-clogged fa.- cleaned recently, wasn't dirty. was cleaned pre season
-flooding carb.- nothing done
-sticky choke- took fa off and looked. was wide open after up to normal operating temp
-weak ign. - plug wires pretty new and don't look degraded, new plugs, new points, condeser, cap and rotor. dwell, 31*, timing 6* btdc...
that leaves the carb. i'm thinking about doing a rebuild..... think i'm on the right track?
oh, i got two 2gc's. the one on the bench is off a 72 165.... i think it's the same as my 75. if i rebuild one, that'd be the one. i have no issues that i'm aware of other than the smoke ring.....
