Smokin' Diode
KiHoPro
I have a question about the electrical on my 1993 Evinrude 48 hp SPL. I rebuilt the lower end and put the two units back together. I went to start my O/B. After some adjustments and a little “Ether”, it fired up and ran great.<br /><br />However after sitting in the damp cool air overnight I couldn’t get it to fire. I checked all connections and wires. Came to a conclusion that the battery needed to be replaced. I purchased a shinny new battery and was set to go. I asked a friend to install the battery while I searched for some tools.<br /><br />My mistake was not to double-check my friend’s work. He installed the battery backwards. I flipped the switch and POP!, accompanied with a little smoke and the wonderful smell of burnt electrical.<br /><br />According to the manual** I may have blow the “Diodes”. *This is all the manual said in regards to this problem. “Verify the battery cables have been PROPERLY connected. If the battery has not been connected correctly the diodes in the circuit will be blow instantly.” Brilliant move! :eek: The manual, did not give a description of where the diodes are located, nor did they give a replacement part number.<br /><br />Can anyone give me some guidance? Can this battery flip issue affect anything else? I.E. the rectifier, coil?<br /><br />Thanks,<br /><br />KiHo<br /><br />* ELECTRICAL 6-14 (Second Paragraph down, first column)<br />** Johnson/Evinrude #1304 Outboards 1990-95 Repair Manual
Dhadley
Re: Smokin' Diode
Welcome!!<br /><br />No maybe about it, the rectifier is popped. It usually doesnt hurt anything else. Sorry to hear about the trouble.<br /><br />Good luck!
KiHoPro
Re: Smokin' Diode
Let me see if I can read between the lines? What you are saying, is that the rectifier houses the diodes? And that I did not blow anything else? Whew!<br /><br />Now where is it? Where is the rectifier located? What does the rectifier look like? I found the wiring bridge.
JB
Re: Smokin' Diode
Moving to JohnnyRude troubles.
JB
Re: Smokin' Diode
Duplicate post.
