Smoking motor??
ngt
Master Chief Petty Officer
So I took my 2008 9.8hp tohatsu 4 stroke out today, ran great, brought it home and went to start it up to flush it.
pull "choke" :) button out
pump the bulb once
pull start the motor
smoke comes out
push "choke" :) in
no more smoke
idles fine
disconnect gas line
run dry
in the garage it goes
Any idea on what the smoke was about?
I had just sprayed the thing down pretty good on the outside. Maybe some water got in somewhere? I don't know...
thanks for the help!
robert graham
Re: Smoking motor??
Sounds like your "pull carb button out" is actually a choke and when you pull it the motor chokes and runs rich, causing smoke?...Also if you're storing your motor laying down flat or tilted up, oil can run down into combustion area and cause smoke when you start it up. Lots of outboards smoke when first cranked up, so it's doubtful you have any big problem here. Good Luck!:)
pvanv
Re: Smoking motor??
Yep. The three things that typically cause that puff of smoke are excessive choking at startup, slight oil making its way to the combustion chambers during handling, and moisture/condensation (which can come from that hosing off). Should not be a cause for concern, but be careful not to get too much water in the intake silencer when hosing off.
ngt
Re: Smoking motor??
Yeah, choke, that's what I meant. Sorry, been a tough day.
I keep my motor on my boat and my boat in the garage. It's never been laid down in the couple of years I've had it. I'm guessing it came from the hosing off or too much choke. Thanks for easing my worries :D
