Snap fastener screw length?
littleape
I need to replace the boat side snap fasteners for the cockpit cover since some of the current ones aren't stainless and are causing rusty streak down the hull.
The current ones use 10mm 1/2" screws and all I seem to be able to find local/amazon, I'm in Canada, are ones with 15mm 5/8" long screws. Any potential issues using longer ones?
littleape
Thanks, this was a little silly but just wanted to make sure :)
Should I pre-drill the extra length or just screw them in?
Put some sealant on the screws when you screw them in
