Snap ring pliers
flyingscott
Who makes a good snap ring pliers to remove the 2 large rings on the OMC lower units. I broke mine today need to replace it.
I used a bluepoint (snap-on's lower end)
flyingscott
Thank you my last one was a 30 yr old snap on that just broke.
flyingscott
They don't even make it anymore and the one they replaced it with I figure will last about a week. The problem is they are so deep in the bullet and so big that any other one I have had has just flexed and you can't get them out.
F_R
The original OMC special tool had a set of extensions to reach that snap ring way up in the nose of some gearcases. I may be wrong, but I believe it was made by Truarc. Even back then, they were $$$.
gm280
Inside or outside rings? They do make some long reach snap ring pliers for such issues. Check around, NAPA stores usually have some tools like that. JMHO!
flyingscott
Think I am going to have to call my Mac and snap on guy again. Napa had an OK one thank you for all the replies I appreciate them.
jakedaawg
Are the original OMC tool available from precision tool? I think so. I have the catalog down in the shop, I'll look tomorrow if I remember. If I don't post back remind via PM and i will get it done. Memory is going to heck.
jakedaawg
Kerr marine tools has them on their outdrive equipment page. Part #50-A
Chinewalker
My father-in-law was a tool and die guy before he retired. He made up a set of pliers from bar stock. I now have them on permanent loan. Considering he doesn't even allow his own son to remove tools from his shop, I consider myself pretty lucky! :biggrin1:
flyingscott
Thank you very much will call kerr tools today. The OTC snap ring pliers are not really up to the task of taking those snap-rings they flex to much. thank you for the suggestion.
jakedaawg
Precision also has them part # SRP110. Precision wholesale marine
Mod note. Sorry of.i broke a rule. Looked here and couldnt find it.
