powerslide
Thread starter- Joined
- Feb 5, 2012
- 47
I have a 78 115 johnson. It ran decent the first two times i took it out, had a slightly cough every 5-10seconds at idle and seemed to idle a little low. None the less it ran great once we got moving.
Last time i took it out it was almost impossible to start and once i got it running it was back firing through the carb.
I bought this from a guy who said he replaced the blue piece under the flywheel because it went out. The arm that goes through the blue piece doesnt appear to be connected correctly it has some black urethane looking material on it and doesnt go all the way in. My understanding is this controls the timing. If its not in the correct location will it cause a miss/backfire?
Another question, the motor has been painted white and the grounds behind the coils dont appear to have been cleaned should i file the paint off and make sure they have a good connection?
