andrew j cox
Thread starter- Joined
- Feb 11, 2015
- 149
Before i burn the boat and engine lets have one more go at trying to solve her problem,
1986 Suzi DT 85 non VRO,
Sat for two seasons though I believe it was longer previous owner was a chronic masturbator.
Engine stunk of stale fuel, first job was pull the carbs and open them up, usual surprises gel, varnish, masses of green verdigras on the main jet, cleaned them out, refitted, drained fuel tank which had water in it, cleaned out with metho let it air dry for a week, new fuel , started her up , sneezing like mad, found one dead coil so fitted new one, made no differance, checked other two coils they are fine, so pulled carbys again this time went right through them again few more bits of rubbish one partially blockedmain jet, refitted, ran great for ten seconds then started sneezing again, i stuck my palm over top carb no differance, stuck palm over middle carb it sucked my palm in and wanted to stall, so i guess shes sucking air in the top carb as i sprayed with carby cleaner she sped up, could be warped carby base or throttle shaft excessive play?
compression good in the motor, its got to fuel related, if its sucking air that will throw the air / fuel mixture out? I set all three screws at 1.5 turns.
what might I be missing, this is a young fellas first boat, he got stung, im trying to get it going, he just wants to go fishing, its driving me to drink lol
