bobleeswagger
Thread starter- Joined
- Aug 19, 2022
- 3
And my wallet keeps getting thinner! 96 Bass Tracker with a 97 Tracker 40hp 2cyl. wont start. Found fried rectifier/regulator. This was a basket case so not sure if it was fried when I got it or I somehow killed it. I am a great shot after all... Looks to be old damage not positive.
The question is what commonly kills the regulator. Just random failure? I did have the key on for hours testing and tracing the wiring as I rebuilt everything. It was basically the hull to start with. Just want to make sure I don't kill a new one if I have the key switched on motor off. (KOEO) The big main 7or 8 pin harness plug on the left side of the motor seems to have a problem. Move it and the 12v battery power dies. I tried zip tying it and that seems to fix it but I don't like it at all. I am looking into that to find a real fix. The radio is connected to the key switch so the key would be on to have the radio on. (and I did ) That could be a problem if this would overheat the Reg just having the radio on.
I thought about a toggle switch to run the radio power. Any suggestions?
Anyone have experience with the 4 wire reg? Will the 5 wire work? Same part number - (815279-4) for both. It has a ground wire that the 4 wire don't have. Any benefit to the 5 wire?
I assume you must have the 4 wire thought I would ask.
Thanks for your help in advance!
