Soaking Yachtwin Carb in Carb cleaner for 24 hours?
LargemouthBass21
I am going to clean my carb this weekend, I have a gallon pail of NAPA (non chlorinated) carb cleaner. I am wondering if any metal damage could occur from soaking overnight? The can says 20 minutes but I know that wont cut it. I have new o rings and gaskets so I'm not worried about that. I'm just concerned that 24 hours could cause damage. (I would disassemble down to parts)
oldboat1
Don't know what the NAPA stuff contains, but long soaking probably won't hurt metal parts. Not sure why it's thought to be necessary. I usually find an hour or two is enough (lacquer thinner), then manually cleaning parts. Need to be sure every orifice is open and clear.
harringtondav
Long soaks in the older, illegal, stuff never damaged the metal in any parts that I cleaned. But some cleaners will deteriorate phenolic and other plastic parts, like valve plate bushings, etc. Keep an eye on these if you have any.
I follow the cleaner soak with a dip in very hot - 140 deg or whatever you water heater can deliver - water and TSP. Then I air blow while it's still hot. Finally follow with an aerosol carb cleaner with the straw purging all passages.
thatone123
Banned
a $100 dollar or less hydro vibration type cleaned works wonders sometimes if you do a few carbs now and then. Most have heaters on them.
LargemouthBass21
Update, tore the carb apart and put a wire through the offices and passages. There was a lot of junk in some of the passages and the jet but I ran a wire through to clean it. There was also a lot of junk in the fixed high speed orifice but I got a lot out and the carb cleaner will help. I have a cheapo electric air compressor which will probably work ok. I’m not paying $20+ for the special OMC screwdriver so I think I can clean it ok with carb cleaner and compressed air. I think this is the reason I could not get the motor to idle last fall. Unfortunately, my propeller now has a big chip that I don’t know where it came from(I haven’t even put it in the water yet). I am sure spending a lot of money on this darn motor...
i am soaking the carb overnight and will check on it tomorrow afternoon
LargemouthBass21
It is in the 40s during the day where I am at, and the temps drop below freezing at night so I think the solevent needs extra time to work
