fiberglass93
Thread starter- Joined
- Aug 20, 2025
- 3
Hi everyone,
I'm in the process of restoring a boat and ran into something I'm not sure about. After ripping out the old carpet, I found a soft layer of something underneath. In some areas it already came loose from water getting behind it and weakening the glue, the rest is still very stuck to the fiberglass hull. I've been scraping it off, but that is very slow.
My questions:
* What was this layer for? Do I need to replace it with something similar? I suspect that it may be for reducing noise, but I'm not sure.
* It wasn't on the floor, just on the sides, why?
* Is there a way to weaken the glue to make the layer easier to scrape off? Maybe heat?
My current plan is to sand both the sides and the floor (both fiberglass) and then apply one or two coats of epoxy resin to seal any small cracks and create a good base layer to work with. Does that sound good?
I have attached some pictures and a short recording. The hull looks weird because of all the glue residue, but I will sand that off once I have this soft layer off.
Thanks!
My questions:
Thanks!
