Soft spot
johnmorgan
I got my first boat now I am going to fixing it up. There is a soft spot near the motor, looks like there is a crack where water is getting in, hope its not to bad. I will need some help on supplys as I go along, coming soon will be some pictures of the soft spot and when I chew into this thing. I have very little fiber glassing experience but am a fast learner. the boat is a 1976 17.5' sangster made in Vancouver b.c I am also putting a new motor in the boat thats the reason for the revamp. latter i want to paint it and make it look like new.
ezmobee
Re: Soft spot
Definitely a cool looking hull worth fixing up. I wouldn't get my hopes up about it's structural condition though. Once you start tearing into these old glassers, you tend to only uncover pain, agony, and despair :p You can fix it though!
johnmorgan
Re: Soft spot
thanks guys looking forward to see what is in there. I hope its not to bad but you are right ez, I seen alot of that on here fingers and toes crossed.
johnmorgan
Re: Soft spot
new for morgan 212.jpgnew for morgan 206.jpg Alright I am back to work on the boat, kinda got side tracked for a long time. The soft spot I need to fix is to the right of the motor. I did get lucky on this boat, the floor has been redone by the P O he said, in 93 he redid the whole thing. the spot that is soft is a rotten 2x4 that extends under the floor, in the pictures you can see the 2x4 that the motor is sitting on. So I am going to start by taking the old motor out and fixing the 2x4 then putting the 95 hp diesel that I am making payments on. so tomorow I am going to starts taking the motor out.
stuff to do.
-take old motor out
-cut up the floor
-fix the rotted wood
-fiber glass the hole
-sand it
-paint it
-paint the rest of the boat
-new gas tanks is in order
thats it for now not going to get ahead of myself
johnmorgan
Re: Soft spot
Well my motor in the boat now has low compression, and also is not safe at all. I went to a volvo shop and the mechanic says he has a diesel for two grand. so I was all over it put a down payment and one more five hundred dollar payment to go. The motor is a md21a 95hp I will have to get a different gear for my leg and she will be good to go. In other words I could not get a better deal for a motor that will bolt to my leg.
johnmorgan
Re: Soft spot
finally figured out how to get these photos up what pita.
badkins50
Re: Soft spot
That is a really good looking boat you got there. I really like those lines. This is going to be a great project and can't wait to see it finished and splashed.
johnmorgan
Re: Soft spot
aq md21a yes pretty old one but from what people tell me a stong reliable motor. The motor has a upraded oil cooler, fresh water cooling system, new fuel filter and new oil filters. The best thing of all, the motor originaly came attached to a 270 outdrive I got pretty lucky that in my little town there was a hidden gem, and the mechanic is an awsome person for letting me make payments.
johnmorgan
Re: Soft spot
boat launch.jpgfound a pic of the boat after its first cruise, and its puller.
johnmorgan
Re: Soft spot
Finally the rain stoped today, got my old motor out getting ready to cut open the soft spot on my deck. I am dreading what is under the deck, but the transom is good, took my samples from around the key hole and drain hole and she is good. I will get some pictures of the progress tomorrow.
