Mark42
- Joined
- Oct 8, 2003
- 9,334
Solar heat. Sounds so easy. But I haven't been able to find a system that does what I want.
My home has hot water baseboard heat, not a good system for supplementing with solar because the system operates at water temps around 185*, well above what solar panels ability . But I can add a solar hot water heater for the tap water with an oil fired backup. That could save a few dollars over the years. And it produces hot tap water 365 days a year.
What I really want is to use solar heat to heat the home during the sunny winter days, and use the oil furnace for heating at night or cloudy days. I think a solar heat system designed to heat radiant floor systems would work with recessed wall heaters. If you're not familiar with recessed wall heaters, they are a radiator in a box that fits inside a wall between studs with a grill face and fan that turns on automatically via a thermo switch. (Toe kick radiators are another variation that go under kitchen cabnets.)
I could add a large recessed wall heaters in three or four stategic locations on the first floor and use the solar hot water during the day to offset the baseboard heat. Seeing as hot air rises, some of the excess heat would rise upstairs warming that area too. If the indoor temps could be run up to the high 70's, there would be some thermal mass to keep the house warm durning the evening (I hope!)
In the evening, when the house temperatures are lower, the upstairs bedrooms will be heated by the oil furnace alone.
I have not been able to find a system that comes with all these parts that I know will work together well. If solar heated water can be used in radiant floor heat system, it should work with with the recessed wall heaters.
Another option is to use the central AC to distribute hot air. The house has central AC, with the air handler in the attic. A radiator could be added to the air box and let the AC fan blow heated air through the house. Just not sure if the air will cool off by the time it comes out the vents.
Anything I could add would help reduce the oil bill. I burn about 1200 gallons of heating oil a year. It would be nice to cut that by 1/3 or 1/2.
If I could find a system that would work for me, I would be willing to tap the home equity loan to pay for it, knowing it is saving me money from the start.
Anyone have solar assisted heat systems in their house? Does it provide a significant amount of hot water or area heat?
