solar battery tenders
jga874
I'm looking for any info anyone might have on solar battery tenders I have dual batteries but no onboard battery charger
Captaincrisp
Im intrested as well, i would like to add batt charger to my 2 batt system...
MH Hawker
i keep a 15 watt panel on mine, and it helps out a bit to keep them topped off, but it takes several days and i just have one battery
ondarvr
To actually charge the batteries you need a big panel, if all you want to do is keep them topped off a smaller one will work. The reason you don't see them on smaller power boats is because the cost and size of the panel needed for it to actually work becomes an issue.
jga874
I just have some cabin lights and the radio so I'm just looking to keep them topped off. I'm just not sure what watt panel will work for that
hemi rt
Get the largest panel you can and also make sure it has a regulator/control panel with it.
