B58, He says the battery drops to 80% when on the water for a day and not being used.
You said you did a "flash charge" and the battery charge meter say's 80% shortly after that.
Have you fully charged the battery and had it tested to know it's good?
Those cheap little light bar meters don't reliably indicate exactly what's going on, just a possible rough estimate of some sort of discharge. Test the battery when fully charged, and then a few hours later with a digital meter. Do this with it connected in the boat, and disconected out of the boat, see if the results change.
