Solar Screens
LadyFish
Last week we had solar screens installed on every window in the house. Our LR and DR face west and the afternoon sun and heat is unbearable no matter what I put on the inside for window treatments. We immediately noticed a slight difference but the rooms still heat up somewhat. Today we are re-caulking every stinkin window to see if this helps further.
Anyone else have solar screens? Do you really think they make a big difference? We were assured a 30% reduction in our eletric bill.
tommays
Re: Solar Screens
I did install anderson high performance sun glass windows in 2 houses
They cut way down on UV fade and i feel the AC has and easyer job
BUT the windows they replaced were so BAD its hard to give hard facts on engery saveings OTHER than much better
Tommays
KRS
Banned
Re: Solar Screens
The type of sunshade material makes a big difference. Is it fabric or metal material? Can you see inside still if the curtains are open and you are standing outside? It should be nearly impossible to see inside.
I've lived in Arizona for over a decade, and we moved last year into our current home, and after installing sun shades it made a huge difference.
Keeping the heat out of the glass (ie: exterior coverings like sunscreens) are the best way to help.
Interior coverings don't keep the heat out of the glass, which just radiates it into your home all day and into the evening.
KRS
Banned
Re: Solar Screens
and.... the reflective light colored screens are better than the black or darker ones, for the obvious reason.
ob
Re: Solar Screens
My brother installs solar screens in the Houston area for a guy in his spare time.That's all I know about them.
LadyFish
Re: Solar Screens
Ob, you're brother's name isn't Bob is it?
KRS, we went with the 90% they are dark and fabric. So far I can tell you the air conditioner isn't running half as much as it used to. Now that the windows have all been caulked I'm hoping for a big reduction in our electric bill.
KRS
Banned
Re: Solar Screens
gotta pay for cozumel somehow 8) , hope they work well, ours sure have.
vipzach
Re: Solar Screens
LF, make sure your attic has plenty of airflow also. We just bought our house a few months ago and with the recent 100+ temps, the AC was not keeping up. I checked the attic and had no way for the heat to go out, just the eve vents, but heat rises..................so they weren't helping. I installed a power attic fan, and what a difference it made. The AC actually keeps up!!! You got me wondering about adding the solar screens now too!!
ob
Re: Solar Screens
LF.No,but my name is Bob.:$ My brother's name is Mike.Are you clairvoyant?d:)
bucky7680
Re: Solar Screens
Ladyfish, we just put 90% shades on the windows at our house on Lake Mead in Arizona. We have not been able to see if there is a reduction in cooling costs yet. But when I put my hand up to the window I can't feel any head coming through. We also like the extra privacy we have with them in place. Our walls are 6" thick with the maximum insulation so the only place we could improve efficiency was with the windows.
Reel Poor
Re: Solar Screens
Dang bucky,,,,,,,,You sure have a way with words......LOL :$
Xcusme
Re: Solar Screens
"LF, make sure your attic has plenty of airflow also. We just bought our house a few months ago and with the recent 100+ temps, the AC was not keeping up. I checked the attic and had no way for the heat to go out, just the eve vents, but heat rises..................so they weren't helping. I installed a power attic fan, and what a difference it made. The AC actually keeps up!!! You got me wondering about adding the solar screens now too!!"
Glad you sorted out one of the most common problems with homes and heat buildup...the attic. It's a common belief that 'heat rises' , actually heat doesn't rise, heated air rises. Heat can travel in any direction. If you were to place a heat source in the center of a large boulder, would the heat only heat the top of the stone? Nope, the heat would migrate in all directions, including down to heat the boulder evenly, from the inside out. Heat tends to migrate from a medium of more heat to a medium of less heat . In a home ceiling, the attic is warmer, the room below is cooler. Heat will migrate downward through the insulation and drywall and heat the room air below. The reason for the insulation is to slow this migration, air is a good insulator, if it isn't moving. In colder climates, when the room is warmer, heat will move up through the drywall and insulation into the attic.
All of this heat energy stuff applies to the vertical walls too. The key to the speed at which this heat is transferred is determined by the temperature differential between the two areas and the insulation that tends to slow the transfer. You can slow this transfer , but you can't stop it. The heat transfer will continue until both sides are at the same temperature. When both sides are equal, the heat transfer will stop.
In a normal hot attic, cooler air in drawn up into the attic through the eve vents. Heated air in the attic should be allowed to leave the attic through roof vents or continuous ridge venting. This updraft carries the heated air (and moisture ) out of the attic, keeping the ambient attic air temperature closer to actual outside temps. Attic temps can reach 180 degrees, that's one heck of a heat source to fight. By venting the attic, and allowing the heated air to rise ,cooler air is drawn in through the eves. Since the attic is cooler, there's less of a temperature differential between the attic and the rooms below, and less heat migrates downward. The homes A/C won't have to work as hard to maintain a cooler temperature.
Multi pane windows filled with inert gasses work well too. The addition of a simple awning to stop the sun from hitting the glass in the first place will keep the glass surfaces much cooler.
LadyFish
Re: Solar Screens
It was explained to me is that 90% of the UV rays and the heat from the sun would be stopped before it ever hits the glass.
We can definetly notice a big difference. The AC used to run nonstop from about 4 p.m. until after 10 p.m. I actually timed it the other day and the AC only ran twice every one and half hours at the same time of day.
Can't wait for the electric bill. :)
