Re: solas rubex 4 blade
Currently with an average to heavy load I will get about 4900 untrimmed, dont have a GPS speed. I say untrimmed because the powertech prop seems to carry the boat higher, you cant really trim out much or it starts to blow out. Plus the rev limiter kicks in at 4950 so Im just guessing it might gain another 100 or so if trimmed out. I feel the tach is accurate because of the rev limiter, and the rpm indicated when it kicks in.
I am not concerned with WOT speed, most of what we do is cruising and pulling tubes/skier etc. Thats why I went with the 19 currently even thought it would pull a 21 in most cases. The problem Im having is I'm getting cavitation with the 19, so I want to try and go to a 4 blade for more grip and low speed power. I just didnt know switching brands how they would act, as Ive read some brands act stronger on pitch than others. I would just like to hook up better at low speed. Not necessarily kill off many rpms because I would rather not lug it through the low speed and midrange.
