Solas vs. Quicksilver
airdvr1227
Chewed up a prop yesterday. Replaced a Solas with the same size and pitch Quicksilver. Noticable difference in performance. Jumps up on plane quicker. I was surprised. Wonder why?
Texasmark
Re: Solas vs. Quicksilver
Simplistic answer, sorry, but because the Merc/Quicksilver prop took things into consideration that Solace obviously didn't. Not that either brand is negligent or anything like that. It's just that maybe one mfgr. concentrated on one set of parameters and the other others and just so happens that Merc hit upon the ones that are important to you and your application.
HTH
Mark
KurtS
How's the midrange, top end, and other characteristics compare?
airdvr1227
Midrange is better. Because I'm mostly on Lake Erie I haven't had it wide open all season. Had a problem a couple of weeks ago where the prop was cavitating under heavy load. Felt like it was spinning on the hub. I think there might have been more wrong with that prop than I thought.
Texasmark
That can happen, especially under heavy loads. Once they start, I wouldn't trust them.
Mark
