jlinder
- Joined
- Jul 5, 2004
- 1,086
Re: Soldering vs, Crimping Volume II
My $.02<br /><br />Solder<br /> Not good for mechanical strength, and it is very easy to do wrong. You can get what is called a cold solder joint where you have a bad electrical connection.<br /><br />Crimp<br /> Provides good mechanical strength and when done correctly a good electrical connection. When you use the correct crimp tool the connection is excellent. The best crimp tool would be a racheting cripmer with dies sized correctly for the splice/lug/etc. With a racheting crimper it will not release until the crimp is correctly made. It can be given to someone with little or no experience and you get reliable crimps all the time (you can screw it up, but it takes effort).<br /><br />Crimp then Solder<br /> I'm not sure of the advantage here, other than shield the crimp from exposure to the elements.<br /><br />Sealing the Connections<br /> Heard lots of good ideas here, but since I am a freshwater sailor I could not comment on how important it becomes when you hit saltwater.<br /><br />Again, My $.02
