Solenoid wiring
steviemc
Could someone help me identify the shift switch on my 1988 125 force engine. I believe it is located on the engine via a bracket near the throttle linkage. This switch is wired directly from the solenoid thru this switch to a yellow wire (start) at the connection bracket/bar. If this is the shift switch could this switch cause my ignition problem? How do I check the switch?
foodfisher
Re: Solenoid wiring
I think what your refering to is the neutral safety switch. Won't let you start in gear. If your ignition problem is it won't start, could be a minor location adjustment. What do you want to check for?
