Solenoid?
Jon1229
new day new problem.. yesterday I replaced the 90 amp fuse on the starter, problem solved. Today I turn the key and the shut off switch to the on positions, the gauges all turn on but the engine doesn’t crank. I can jump the boat from the solenoid and it starts right up, but next time I go to start it I need to jump the solenoid again. When I shut off the key the engine stops. I replaced the solenoid maybe a month ago, which is weird that it would already be bad. Any ideas?
Ayuh,..... Check that the key switch is passin' power to the yellow/ red wire in the start position,....
Jon1229
So with a voltmeter check Red/ground and then yellow ground when it’s turned all the way?
Ayuh,..... The Start Circuit is the Yellow/ Red wire, from the key switch, to the solenoids,....
1 wire, 2 colors,.....
